s'authentifier
version française rss feed
inria-00166711, version 1
The Delaunay Hierarchy
Olivier Devillers () a1
International Journal of Foundations of Computer Science 13 (2002) 163-180
Résumé : We propose a new data structure to compute the Delaunay triangulation of a set of points in the plane. It combines good worst case complexity, fast behavior on real data, small memory occupation and the possibility of fully dynamic insertions and deletions. The location structure is organized into several levels. The lowest level just consists of the triangulation, then each level contains the triangulation of a small sample of the level below. Point location is done by walking in a triangulation to determine the nearest neighbor of the query at that level, then the walk restarts from that neighbor at the level below. Using a small subset (3%) to sample a level allows a small memory occupation; the walk and the use of the nearest neighbor to change levels quickly locate the query.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00166711, version 1
  • oai:hal.inria.fr:inria-00166711
  • Contributeur :
  • Soumis le : Mercredi 8 Août 2007, 19:10:52
  • Dernière modification le : Mercredi 8 Août 2007, 22:12:56
tous les articles de la base du CCSd...
