s'authentifier
version française rss feed
inria-00167201, version 1
On Deletion in Delaunay Triangulations
Olivier Devillers () a1
International Journal of Computational Geometry & Applications 12 (2002) 193-205
Résumé : This paper presents how the space of spheres and shelling may be used to delete a point from a $d$-dimensional triangulation efficiently. In dimension two, if k is the degree of the deleted vertex, the complexity is O(k log k), but we notice that this number only applies to low cost operations, while time consuming computations are only done a linear number of times. This algorithm may be viewed as a variation of Heller's algorithm [Heller, Symp. Spatial Data Handling 1990] which is popular in the geographic information system community. Unfortunately, Heller algorithm is false, as explained in this paper.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00167201, version 1
  • oai:hal.inria.fr:inria-00167201
  • Contributeur :
  • Soumis le : Jeudi 16 Août 2007, 14:30:43
  • Dernière modification le : Jeudi 16 Août 2007, 14:48:21
tous les articles de la base du CCSd...
