inria-00167206, version 1
Randomization Yields Simple O(n log* n) Algorithms for Difficult Omega(n) Problems
International Journal of Computational Geometry & Applications 2, 1 (1992) 97-111
Résumé : We use here the results on the influence graph to adapt them for particular cases where additional information is available. In some cases, it is possible to improve the expected randomized complexity of algorithms from O(n log n) to O(n log* n). This technique applies in the following applications: triangulation of a simple polygon, skeleton of a simple polygon, Delaunay triangulation of points knowing the EMST (euclidean minimum spanning tree).
- a – INRIA
- 1 : GEOMETRICA (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Géométrie algorithmique
- inria-00167206, version 1
- http://hal.inria.fr/inria-00167206
- oai:hal.inria.fr:inria-00167206
- Contributeur : Olivier Devillers
- Soumis le : Jeudi 16 Août 2007, 15:00:01
- Dernière modification le : Jeudi 3 Septembre 2009, 14:46:53
Documents associés
Exporter
