AmI: The Future is Now – A position paper
Because of the unique nature of the AmI domain, specifically the high amount of industrial involvement in this area, we fear that a classical long-term scenario for the use of academic research is no longer valid. In this paper we argue that the AmI research community should adapt to this context. To do this, we consider a short-term approach, and raise some points for discussion.
