inria-00168163, version 1
Further Results on Arithmetic Filters for Geometric Predicates
Olivier Devillers
a, 1Franco Preparata b, 2
Computational Geometry 13 (1999) 141-148
Résumé : An efficient technique to solve precision problems consists in using exact computations. For geometric predicates, using systematically expensive exact computations can be avoided by the use of filters. The predicate is first evaluated using rounding computations, and an error estimation gives a certificate of the validity of the result. In this note, we studies the statistical efficiency of filters for cosphericity predicate with an assumption of regular distribution of the points. We prove that the expected value of the polynomial corresponding to the in sphere test is greater than epsilon with probability O(epsilon log 1/epsilon) improving the results of a previous paper.
- a – INRIA
- b – John Brown University
- 1 : GEOMETRICA (INRIA Sophia Antipolis)
- INRIA
- 2 : Department of Computer Science (Brown University)
- Brown University
- Domaine : Informatique/Géométrie algorithmique
- inria-00168163, version 1
- http://hal.inria.fr/inria-00168163
- oai:hal.inria.fr:inria-00168163
- Contributeur : Olivier Devillers
- Soumis le : Vendredi 24 Août 2007, 17:42:10
- Dernière modification le : Vendredi 24 Août 2007, 17:43:30
Documents associés
Exporter
