Convergence and rate of convergence of a simple ant model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Amine Boumaza
  • Fonction : Auteur
  • PersonId : 830929
Bruno Scherrer
We present a simple ant model that solves a discrete foraging problem. We describe simulations and provide a complete convergence analysis: we show that the ant population computes the solution of some optimal control problem and converges in some well defined sense. We discuss the rate of convergence with respect to the number of ants: we give experimental and theoretical arguments that suggest that this convergence rate is superlinear with respect to the number of agents. Furthermore, we explain how this model can be extended in order to solve optimal control problems in general and argue that such an approach can be applied to any problem that involves the computation of the fixed point of a contraction mapping. This allows to design a large class of formally well understood ant like algorithms.
aamas.pdf (183.19 Ko) Télécharger le fichier
inria-00170186 , version 1 (06-09-2007)
  • HAL Id : inria-00170186 , version 1
Amine Boumaza, Bruno Scherrer. Convergence and rate of convergence of a simple ant model. International Conference on Autonomous Agents and Multiagent Systems - AAMAS'07, May 2007, Honolulu Hawaii, United States. pp.607-609. ⟨inria-00170186⟩
131 Consultations
90 Téléchargements
