Characterization of graphs and digraphs with small process number - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
The process number of a digraph has been introduced as a tool to study rerouting issues in WDM networks. We consider the recognition and the characterization of (di)graphs with process number at most two.
RR-6285-v2.pdf (370.31 Ko) Télécharger le fichier
inria-00171083 , version 1 (11-09-2007)
inria-00171083 , version 2 (11-09-2007)
inria-00171083 , version 3 (12-09-2007)
inria-00171083 , version 4 (29-01-2008)
  • HAL Id : inria-00171083 , version 4
David Coudert, Jean-Sébastien Sereni. Characterization of graphs and digraphs with small process number. [Research Report] RR-6285, INRIA. 2008, pp.26. ⟨inria-00171083v4⟩
249 Consultations
175 Téléchargements
