A Phase Transition-based Perspective on Multiple Instance Kernels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper is concerned with relational Support Vector Machines, at the intersection of Support Vector Machines (SVM) and relational learning or Inductive Logic Programming (ILP). The so-called phase transition framework, primarily developed for constraint satisfaction problems (CSP), has been extended to ILP, providing relevant insights into the limitations and difficulties thereof. The goal of this paper is to examine relational SVMs and specifically Multiple Instance-SVMs in the phase transition perspective. Introducing a relaxed CSP formalization of MI-SVMs, we first derive a lower bound on the MI-SVM generalization error in terms of the CSP satisfiability probability. Further, ample empirical evidence based on systematic experimentations demonstrates the existence of a unsatisfiability region, entailing the failure of MI-SVM approaches.
CAP_07.pdf (616.88 Ko) Télécharger le fichier
inria-00171406 , version 1 (12-09-2007)
  • HAL Id : inria-00171406 , version 1
Romaric Gaudel, Michèle Sebag, Antoine Cornuéjols. A Phase Transition-based Perspective on Multiple Instance Kernels. Conférence francophone sur l'apprentissage automatique, Jean-Daniel Zucker, Antoine Cornuéjols, Jul 2007, Grenoble, France. pp.173--186. ⟨inria-00171406⟩
442 Consultations
156 Téléchargements
