Usage based indexing of web resources with natural language processing
Due to the huge amount of available information via Internet, the identification of reliable and interesting items becomes more and more difficult and time consuming. This paper is a position paper describing our intended work in the framework of multimedia information retrieval by browsing techniques within web navigation. It relies on a usage-based indexing of resources: we ignore the nature, the content and the structure of resources. We describe a new approach taking advantage of the similarity between statistical modeling of language and document retrieval systems. A syntax of usage is computed that designs a Statistical Grammar of Usage (SGU). A SGU enables resources classification to perform a personalized navigation assistant tool. It relies both on collaborative filtering to compute virtual communities of users and a new distance dependent trigger model. The resulting SGU is a community dependent SGU.
