inria-00172412, version 2
Biological model of motion integration and segmentation based on form cues
Émilien Tlapale
1Guillaume S. Masson 2Pierre Kornprobst
1
N° RR-6293 (2007)
Résumé : Active vision is an essential part of every biological organism possessing an eye system: posture, eye movements, visual research, ... All require a motion percept to operate. At the basis of active vision lays the ability to calculate movements of objects in the scene, at least on a sufficient level to react correctly. In this report we present a model of motion integration and segmentation in the first visual cortex areas. Specifically we modeled the first two cortex areas involved in motion processing in the primate: V1 and MT. To be able to process motion correctly a visual system also need to deal with form information. We investigate how form cues coming from the ventral pathway can be used by the V1/MT dorsal pathway to solve some perception problems. By using a recurrent dynamical system between the V1 and MT layers we are able to find out psychophysical results such as motion integration and center-surround effects due to the feedback connections, or end-of-line and 2D features detectors thanks to the shunting inhibition. We propose to modulate this system by a form information coming from the ventral stream and are thus able to explain asymmetric center-surround effects as well as motion segmentation and segregation between extrinsic and intrinsic junctions.
- 1 : ODYSSEE (INRIA Sophia Antipolis)
- INRIA – Ecole des Ponts ParisTech – Ecole Normale Supérieure de Paris - ENS Paris
- 2 : Institut de neurosciences cognitives de la méditerranée (INCM)
- CNRS : UMR6193 – Université de la Méditerranée - Aix-Marseille II
- Domaine : Sciences du Vivant/Neurosciences
- Mots-clés : motion estimation – optical flow – bio-inspired vision – MT area – feedbacks – center-surround integration – shunting inhibition
- Référence interne : RR-6293
- Versions disponibles : v1 (17-09-2007) v2 (17-09-2007)
- inria-00172412, version 2
- http://hal.inria.fr/inria-00172412
- oai:hal.inria.fr:inria-00172412
- Contributeur : Émilien Tlapale
- Soumis le : Lundi 17 Septembre 2007, 13:37:03
- Dernière modification le : Jeudi 16 Octobre 2008, 14:15:57
Documents associés
Exporter
