Regularity results for the Primitive Equations of the ocean - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 2006
We consider the linear Primitive Equations of the ocean in the three dimensional space, with horizontal periodic and vertical Dirichlet boundary conditions. Thanks to Fourier transforms we are able to calculate explicitly the pressure term. We then state existence, unicity and regularity results for the linear time-depending Primitive Equations, with low-regularity right-hand side.
Nodet_RegulEqPrim_v2.pdf (254.9 Ko) Télécharger le fichier
inria-00173075 , version 1 (19-09-2007)
  • HAL Id : inria-00173075 , version 1
Maëlle Nodet. Regularity results for the Primitive Equations of the ocean. Asymptotic Analysis, 2006, 50 (3/4), pp.293-324. ⟨inria-00173075⟩
107 Consultations
104 Téléchargements
