A Composite Mixed Finite Elements for General Hexahedral Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new mixed finite element method on three-dimensional general hexahedral meshes for second order elliptic problems is proposed. This finite element is composite and is shown to have optimal convergence properties.
rapInriaSbouiJaffreRoberts.pdf (993.84 Ko) Télécharger le fichier
inria-00173453 , version 1 (19-09-2007)
inria-00173453 , version 2 (20-09-2007)
  • HAL Id : inria-00173453 , version 2
Amel Sboui, Jérôme Jaffré, Jean E. Roberts. A Composite Mixed Finite Elements for General Hexahedral Grids. [Research Report] RR-6300, INRIA. 2007, pp.27. ⟨inria-00173453v2⟩
99 Consultations
181 Téléchargements
