Active Tags : mastering XML with XML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Philippe Poulard
  • Fonction : Auteur
  • PersonId : 842799
Many XML languages are defining tags for processing purpose rather than for describing datas : XSLT, Apache's Ant, or more recently XProc. They are all focusing on a single problematic but could rely on a common framework that would supply a set of services and interfaces. This paper discusses Active Tags, a language-independant and general-purpose XML system for native XML programming, that aims to be a generic runtime container for several runnable markup languages. We'll depict the architecture of the system and show a few of its features : browsing non-XML datas with XPath, designing macro-tags, mixing declarative sentences with imperative constructs, and filtering SAX streams with XPath patterns.
EML2007Poulard01.pdf (454.39 Ko) Télécharger le fichier
eml2007-active-tags.pdf (515.49 Ko) Télécharger le fichier
Format : Autre
inria-00173716 , version 1 (20-09-2007)
  • HAL Id : inria-00173716 , version 1
Philippe Poulard. Active Tags : mastering XML with XML. Extreme Markup Languages, Aug 2007, Montréal, Canada. ⟨inria-00173716⟩
104 Consultations
246 Téléchargements
