s'authentifier
version française rss feed
inria-00174077, version 1
Mutual information for the selection of relevant variables in spectrometric nonlinear modelling
Fabrice Rossi () 1, Amaury Lendasse () 2, Damien François () 3, Vincent Wertz () 3, Michel Verleysen 4
Chemometrics and Intelligent Laboratory Systems / I Mathematical Background Chemometrics Intell Lab Syst 80, 2 (2006) 215-226
Résumé : Data from spectrophotometers form vectors of a large number of exploitable variables. Building quantitative models using these variables most often requires using a smaller set of variables than the initial one. Indeed, a too large number of input variables to a model results in a too large number of parameters, leading to overfitting and poor generalization abilities. In this paper, we suggest the use of the mutual information measure to select variables from the initial set. The mutual information measures the information content in input variables with respect to the model output, without making any assumption on the model that will be used; it is thus suitable for nonlinear modelling. In addition, it leads to the selection of variables among the initial set, and not to linear or nonlinear combinations of them. Without decreasing the model performances compared to other variable projection methods, it allows therefore a greater interpretability of the results.
  • Domaine : Chimie/Chemo-informatique
    Informatique/Apprentissage
    Informatique/Réseau de neurones
    Mathématiques/Statistiques
  • Mots-clés : Chemometrics – Mutual information – Feature selection – LS-SVM – RBF
  • inria-00174077, version 1
  • oai:hal.inria.fr:inria-00174077
  • Contributeur :
  • Soumis le : Vendredi 21 Septembre 2007, 14:36:40
  • Dernière modification le : Vendredi 21 Septembre 2007, 14:49:57
tous les articles de la base du CCSd...
