Grid-enabling medical image analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Clinical Monitoring and Computing Année : 2005
Yann Gaudeau
  • Fonction : Auteur
  • PersonId : 757476
  • IdRef : 112706266
Emmanuel Jeannot
Grids have emerged as a promising technology to handle the data and compute intensive requirements of many application areas. Digital medical image processing is a promising application area for grids. Given the volume of data, the sensitivity of medical information, and the joint complexity of medical datasets and computations expected in clinical practice, the challenge is to fill the gap between the grid middleware and the requirements of clinical applications. The research project AGIR (Grid Analysis of Radiological Data) presented in this paper addresses this challenge through a combined approach: on one hand, leveraging the grid middleware through core grid medical services which target the requirements of medical data processing applications; on the other hand, grid-enabling a panel of applications ranging from algorithmic research to clinical applications.
AGIRJCMCALL.PDF (1.07 Mo) Télécharger le fichier
inria-00174284 , version 1 (22-09-2007)
Cécile Germain-Renaud, Vincent Breton, Patrick Clarysse, Yann Gaudeau, Tristan Glatard, et al.. Grid-enabling medical image analysis. International Journal of Clinical Monitoring and Computing, 2005, 19 (4-5), pp.339-349. ⟨10.1007/s10877-005-0679-9⟩. ⟨inria-00174284⟩
521 Consultations
327 Téléchargements
