Snapshot of MAC, PHY and Propagation Models for IEEE 802.11 in Open-Source Network Simulators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Simulation is an essential component of the validation chain in the design of network protocols. Indeed, while simulation is not the only tool used for data networking research, it is extremely useful because it often allows research questions and prototypes to be explored at many orders-of-magnitude less cost and time than that required to experiment with real implementations and networks. In this report, we focus on the simulation of IEEE 802.11 Physical (PHY) and Medium Access Control (MAC) layers and provide a survey of current IEEE 802.11 network simulators. We believe that such survey will help network researchers to select the best simulator according to the requirements of their simulations. Furthermore, we present a detailed description of the YANS prototype network simulator, and especially its physical layer imple-mentation, which will be partly ported in the upcoming NS-3 network simulator.
RR-6310.pdf (300.74 Ko) Télécharger le fichier
inria-00175359 , version 1 (27-09-2007)
inria-00175359 , version 2 (28-09-2007)
  • HAL Id : inria-00175359 , version 2
Masood Khosroshahy, Thierry Turletti, Katia Obraczka. Snapshot of MAC, PHY and Propagation Models for IEEE 802.11 in Open-Source Network Simulators. [Research Report] RR-6310, INRIA. 2007, pp.20. ⟨inria-00175359v2⟩
129 Consultations
980 Téléchargements
