Identification of the Isotherm Function in Chromatography Using CMA-ES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Mohamed Jebalia
  • Fonction : Auteur
  • PersonId : 842777
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Marc Schoenauer
Marie Postel
This paper deals with the identification of the flux for a system of conservation laws in the specific example of analytic chromatography. The fundamental equations of chromatographic process are highly non linear. The state-of-the-art Evolution Strategy, CMA-ES (the Covariance Matrix Adaptation Evolution Strategy), is used to identify the parameters of the so-called isotherm function. The approach was validated on different configurations of simulated data using either one, two or three components mixtures. CMA-ES is then applied to real data cases and its results are compared to those of a gradient-based strategy.
CEC_2007.pdf (293.79 Ko) Télécharger le fichier
inria-00175852 , version 1 (01-10-2007)
Mohamed Jebalia, Anne Auger, Marc Schoenauer, Francois James, Marie Postel. Identification of the Isotherm Function in Chromatography Using CMA-ES. IEEE Congress on Evolutionary Computation, Sep 2007, Singapour, Singapore. pp.4289-4296, ⟨10.1109/CEC.2007.4425031⟩. ⟨inria-00175852⟩
366 Consultations
259 Téléchargements
