s'authentifier
version française rss feed
inria-00176007, version 1
Battling windmills with Coq: formal verification of a compilation algorithm for parallel moves
Laurence Rideau () a1, Bernard P. Serpette () a2, Xavier Leroy () a3
Résumé : This article describes the formal verification of a compilation algorithm that transforms parallel moves (parallel assignments between variables) into a semantically-equivalent sequence of elementary moves. Two different specifications of the algorithm are given: an inductive specification and a functional one, each with its correctness proofs. A functional program can then be extracted and integrated in the Compcert verified compiler.
  • Domaine : Informatique/Logique en informatique
  • inria-00176007, version 1
  • oai:hal.inria.fr:inria-00176007
  • Contributeur :
  • Soumis le : Mardi 2 Octobre 2007, 11:15:14
  • Dernière modification le : Mardi 2 Octobre 2007, 14:06:38
tous les articles de la base du CCSd...
