inria-00176204, version 1
Empty-ellipse graphs
Olivier Devillers
1, 2Jeff Erickson a, 3Xavier Goaoc
4
19th Annual ACM-SIAM Symposium on Discrete Algorithms (SODA'08) (2008) 1249--1256
Résumé : We define and study a geometric graph over points in the plane that captures the local behavior of Delaunay triangulations of points on smooth surfaces in 3-space. Two points in a planar point set P are neighbors in the empty-ellipse graph if they lie on an axis-aligned ellipse with no point of P in its interior. The empty-ellipse graph can be a clique in the worst case, but it is usually much less dense. Specifically, the emptyellipse graph of n points has complexity Θ(Δn) in the worst case, where Δ is the ratio between the largest and smallest pairwise distances. For points generated uniformly at random in a rectangle, the empty-ellipse graph has expected complexity Θ(n log n). As an application of our proof techniques, we show that the Delaunay triangulation of n random points on a circular cylinder has expected complexity Θ(n log n).
- a – University of Illinois at Urbana Champaign
- 1 : GEOMETRICA (INRIA Sophia Antipolis)
- INRIA
- 2 : INRIA Sophia Antipolis (INRIA Sophia Antipolis)
- INRIA
- 3 : Dept. of Computer Science
- University of Illinois
- 4 : VEGAS (INRIA Lorraine - LORIA)
- INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine
- Domaine : Informatique/Géométrie algorithmique
- inria-00176204, version 1
- http://hal.inria.fr/inria-00176204
- oai:hal.inria.fr:inria-00176204
- Contributeur : Xavier Goaoc
- Soumis le : Mardi 2 Octobre 2007, 18:53:13
- Dernière modification le : Vendredi 31 Octobre 2008, 12:02:32
Documents associés
Exporter
