Control Flow to Detect Malware - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This study proposes a malware detection strategy based on control flow. It consists in searching in the control flow graph of the analysed program for an induced sub-graph which corresponds to the control flow graphs of a malicious program. The resulting detector is build over a strong theoretical framework.Finally, experiments are carried out in order to evaluates the proposed detection strategy.
IRWRSDA.pdf (192.02 Ko) Télécharger le fichier
inria-00176241 , version 1 (03-10-2007)
  • HAL Id : inria-00176241 , version 1
Guillaume Bonfante, Matthieu Kaczmarek, Jean-Yves Marion. Control Flow to Detect Malware. Inter-Regional Workshop on Rigorous System Development and Analysis 2007, Pascal Fontaine; Stephan Merz, Oct 2007, Nancy, France. ⟨inria-00176241⟩
177 Consultations
843 Téléchargements
