Optimistic Non-repudiation Protocol Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Non-repudiation protocols with session labels have a number of vulnerabilities. Recently Cederquist, Corin and Dashti have proposed an optimistic non-repudiation protocol that avoids altogether the use of session labels. We have specified and analysed this protocol using an extended version of the AVISPA Tool and one important fault has been discovered. We describe the protocol, the analysis method, show two attack traces that exploit the fault and propose a correction to the protocol.
SantiagoV-WISTP07.pdf (159.6 Ko) Télécharger le fichier
inria-00176333 , version 1 (03-10-2007)
Judson Santos Santiago, Laurent Vigneron. Optimistic Non-repudiation Protocol Analysis. Information Security Theory and Practices - Smart Cards, Mobile and Ubiquitous Computing Systems, May 2007, Heraklion, Greece. pp.90-101, ⟨10.1007/978-3-540-72354-7_8⟩. ⟨inria-00176333⟩
117 Consultations
287 Téléchargements
