Secure data transmission based on multi-input multi-output delayed chaotic system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International journal of bifurcation and chaos in applied sciences and engineering Année : 2008
This paper deals with the problem of secure data transmission based on multi-input multi-output delayed chaotic systems. A new multi-input secure data transmission scheme is proposed. Moreover, in order to increase again the robustness of secure data transmission, delays are introduced as a second firewall against known plain-text attack. With thismethod, the parameters used as secret keys of the system are not identifiable and, as a result, the proposed scheme is robust to known plain-text attacks.
Automatique
IJBC_HAL.pdf (264.79 Ko) Télécharger le fichier
inria-00176896 , version 1 (04-10-2007)
inria-00176896 , version 2 (23-10-2007)
Gang Zheng, Driss Boutat, Thierry Floquet, Jean-Pierre Barbot. Secure data transmission based on multi-input multi-output delayed chaotic system. International journal of bifurcation and chaos in applied sciences and engineering , 2008, 18 (7), pp.2063-2072. ⟨10.1142/S0218127408021567⟩. ⟨inria-00176896v2⟩
495 Consultations
300 Téléchargements
