Decoupling the CGAL 3D Triangulations from the Underlying Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Manuel Caroli
  • Fonction : Auteur
  • PersonId : 843218
Nico Kruithof
  • Fonction : Auteur
  • PersonId : 843219
Monique Teillaud
The {\em Computational Geometry Algorithms Library} {\sc Cgal} currently provides packages to compute triangulations in $\mathbb{R}^2$ and $\mathbb{R}^3$. In this paper we describe a new design for the 3D triangulation package that permits to easily add functionality to compute triangulations in other spaces. These design changes have been implemented, and validated on the case of the periodic space $\T^3$. We give a detailed description of the realized changes together with their motivation. Finally, we show benchmarks to prove that the new design does not affect the efficiency.
RR-6318.pdf (459.06 Ko) Télécharger le fichier
inria-00177516 , version 1 (08-10-2007)
inria-00177516 , version 2 (26-12-2007)
  • HAL Id : inria-00177516 , version 2
Manuel Caroli, Nico Kruithof, Monique Teillaud. Decoupling the CGAL 3D Triangulations from the Underlying Space. [Research Report] RR-6318, INRIA. 2007, pp.12. ⟨inria-00177516v2⟩
188 Consultations
413 Téléchargements
