Parameter Setting for Evolutionary Latent Class Clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The latent class model or multivariate multinomial mixture is a powerful model for clustering discrete data. This model is expected to be useful to represent non-homogeneous populations. It uses a conditional independence assumption given the latent class to which a statistical unit is belonging. However, it leads to a criterion that proves difficult to optimise by the standard approach based on the EM algorithm. An Evolutionary Algorithms is designed to tackle this discrete optimisation problem, and an extensive parameter study on a large artificial dataset allows to derive stable parameters. Those parameters are then validated on other artificial datasets, as well as on some well-known real data: the Evolutionary Algorithm performs repeatedly better than other standard clustering techniques on the same data.
latentEA.pdf (189.83 Ko) Télécharger le fichier
inria-00179186 , version 1 (14-10-2007)
  • HAL Id : inria-00179186 , version 1
Damien Tessier, Marc Schoenauer, Christophe Biernacki, Gilles Celeux, Gérard Govaert. Parameter Setting for Evolutionary Latent Class Clustering. Second International Symposium, ISICA 2007, Sep 2007, Wuhan, China. pp.472-484. ⟨inria-00179186⟩
327 Consultations
201 Téléchargements
