Single output dependent quadratic observability normal form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, two quadratic observability normal forms dependent on output respectively correspondent to drift dominant term and forced dominant term are firstly discussed. Moreover characteristic numbers are studied in order to simplify the calculation of these two normal forms.
Automatique
NOLCOS07_HAL.pdf (125.5 Ko) Télécharger le fichier
inria-00179222 , version 1 (14-10-2007)
Gang Zheng, Driss Boutat, Jean-Pierre Barbot. Single output dependent quadratic observability normal form. NOLCOS 2007 - 7th IFAC Symposium on Nonlinear Control Systems, Aug 2007, Pretoria, South Africa. pp.432-437, ⟨10.3182/20070822-3-ZA-2920.00071⟩. ⟨inria-00179222⟩
315 Consultations
199 Téléchargements
