inria-00179731, version 1
Lossless filter for multiple repetitions with Hamming distance
Pierre Peterlongo
a, 1Nadia Pisanti
2Frédéric Boyer
3Alair Pereira Do Lago 4Marie-France Sagot
a, 3
Journal of Discrete Algorithms (2007)
Résumé : Similarity search in texts, notably in biological sequences, has received substantial attention in the last few years. Numerous filtration and indexing techniques have been created in order to speed up the solution of the problem. However, previous filters were made for speeding up pattern matching, or for finding repetitions between two strings or o ccurring twice in the same string. In this paper, we present an algorithm called Nimbus for filtering strings prior to finding repetitions o ccurring twice or more in a string, or in two or more strings. Nimbus uses gapped seeds that are indexed with a new data structure, called a bi-factor array, that is also presented in this paper. Experimental results show that the filter can be very efficient: preprocessing with Nimbus a data set where one wants to find functional elements using a multiple lo cal alignment to ol such as Glam, the overall execution time can be reduced from 7.5 hours to 2 minutes.
- a – INRIA
- 1 : SYMBIOSE (INRIA - IRISA)
- CNRS : UMR6074 – INRIA – INSA Rennes – Université de Rennes 1
- 2 : Department of Computer Science [Pisa]
- UNIVERSITÀ DEGLI STUDI DI PISA
- 3 : HELIX (INRIA Rhône-Alpes)
- INRIA – CNRS : UMR5558 – Université Claude Bernard - Lyon I
- 4 : Departamento de Ciência da Computação [São Paulo] (IME/USP)
- Universidade de São Paulo
- Collaboration : Équipes associées INRIA
- Domaine : Informatique/Bio-informatique
Sciences du Vivant/Bio-Informatique, Biologie Systémique
- inria-00179731, version 1
- http://hal.inria.fr/inria-00179731
- oai:hal.inria.fr:inria-00179731
- Contributeur : Pierre Peterlongo
- Soumis le : Mardi 23 Octobre 2007, 10:43:14
- Dernière modification le : Mardi 23 Octobre 2007, 11:52:05
Documents associés
Exporter
