A Bayesian classifier for symbol recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present in this paper an original adaptation of Bayesian networks to symbol recognition problem. More precisely, a descriptor combination method, which enables to improve significantly the recognition rate compared to the recognition rates obtained by each descriptor, is presented. In this perspective, we use a simple Bayesian classifier, called naive Bayes. In fact, probabilistic graphical models, more specifically Bayesian networks, are a simple and intuitive way of probability distribution representation. In order to solve the dimensionality problem, we use a variable selection method. Experimental results, obtained in a supervised learning context and tested on GREC symbol database, are very promising.
GREC07.pdf (105.55 Ko) Télécharger le fichier
inria-00179764 , version 1 (17-10-2007)
  • HAL Id : inria-00179764 , version 1
Sabine Barrat, Salvatore Tabbone, Patrick Nourrissier. A Bayesian classifier for symbol recognition. Seventh International Workshop on Graphics Recognition - GREC'2007, IAPR TC-10 (Technical Committee on Graphics Recognition), Sep 2007, Curitiba, Brazil. 9 p. ⟨inria-00179764⟩
96 Consultations
477 Téléchargements
