s'authentifier
version française rss feed
inria-00180004, version 1
Mapping sequences by parts
Gilles Didier a1, Carito Guziolowski () b2
Algorithms for Molecular Biology 2 (2007) 11
Résumé : We present the N-map method, a pairwise and asymmetrical approach which allows us to compare sequences by taking into account evolutionary events that produce shuffled, reversed or repeated elements. Basically, the optimal N-map of a sequence s over a sequence t is the best way of partitioning the first sequence into N parts and placing them, possibly complementary reversed, over the second sequence in order to maximize the sum of their gapless alignment scores.
  • Domaine : Informatique/Bio-informatique
  • inria-00180004, version 1
  • oai:hal.inria.fr:inria-00180004
  • Contributeur :
  • Soumis le : Mercredi 17 Octobre 2007, 14:11:46
  • Dernière modification le : Vendredi 19 Octobre 2007, 10:29:07
tous les articles de la base du CCSd...
