A brief overview of intracortical circuits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
François Grimbert
  • Fonction : Auteur
  • PersonId : 840532
This report aims at giving an insight of the most salient features of intracortical connectivity, i.e., the structure of neuronal networks inside a cortical area. In the first part we raise the question of cortical columns, a blur and sometimes misused concept defining fundamental mesoscopic units in the cortex. Their role and structure show a lot of discrepancies across species and even across areas. In the second part, we focus on local circuits and try to get an insight of their complexity as well as their most important organizing laws, like the stereotypical excitatory pathway. The last part is dedicated to horizontal connectivity, illustrated through two famous examples: the primary visual cortex of mammals and the rat barrel cortex.
RR-6325.pdf (1.46 Mo) Télécharger le fichier
inria-00180386 , version 1 (18-10-2007)
inria-00180386 , version 2 (22-10-2007)
  • HAL Id : inria-00180386 , version 2
François Grimbert. A brief overview of intracortical circuits. [Research Report] RR-6325, INRIA. 2007. ⟨inria-00180386v2⟩
119 Consultations
606 Téléchargements
