inria-00181029, version 2
A Multi-level Blocking Distinct Degree Factorization Algorithm
Richard P. Brent a, 1Paul Zimmermann
2
Contemporary Mathematics 461 (2008) 47-58
Résumé : We give a new algorithm for performing the distinct-degree factorization of a polynomial P(x) over GF(2), using a multi-level blocking strategy. The coarsest level of blocking replaces GCD computations by multiplications, as suggested by Pollard (1975), von~zur Gathen and Shoup (1992), and others. The novelty of our approach is that a finer level of blocking replaces multiplications by squarings, which speeds up the computation in GF(2)[x]/P(x) of certain interval polynomials when P(x) is sparse. As an application we give a fast algorithm to search for all irreducible trinomials x^r + x^s + 1 of degree r over GF(2), while producing a certificate that can be checked in less time than the full search. Naive algorithms cost O(r^2) per trinomial, thus O(r^3) to search over all trinomials of given degree r. Under a plausible assumption about the distribution of factors of trinomials, the new algorithm has complexity O(r^2 (log r)^{3/2}(log log r)^{1/2}) for the search over all trinomials of degree r. Our implementation achieves a speedup of greater than a factor of 560 over the naive algorithm in the case r = 24036583 (a Mersenne exponent). Using our program, we have found two new primitive trinomials of degree 24036583 over GF(2) (the previous record degree was 6972593).
- a – Australian National University
- 1 : Mathematical Sciences Institute (MSI)
- Australian National University
- 2 : CACAO (INRIA Lorraine - LORIA)
- CNRS : UMR7503 – INRIA – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
- Collaboration : Grid'5000
- Domaine : Informatique/Algorithme et structure de données
- Mots-clés : Amortized complexity – distinct degree factorization – finite field – irreducible trinomial – Mersenne exponent – polynomial factorization – primitive trinomial
- Versions disponibles : v1 (24-10-2007) v2 (24-10-2007)
- inria-00181029, version 2
- http://hal.inria.fr/inria-00181029
- oai:hal.inria.fr:inria-00181029
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mercredi 24 Octobre 2007, 11:17:28
- Dernière modification le : Mardi 24 Avril 2012, 09:42:48
Documents associés
Exporter
