Discussions on observability and invertibility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, new definitions of observability are introduced. They include states and/or inputs estimation, as well as partial or global observability. From these definitions, problems of left invertibility, fault detection, observability, identifiability, unidirectional synchronization,... can be studied in the same context. Moreover, we propose the definitions for both nonlinear continuous-time systems and switched systems. Two examples are introduced to illustrate the efficiency of the proposed definitions and related propositions introduce in the paper.
NOLCOSWJPhal2.pdf (182.94 Ko) Télécharger le fichier
inria-00182433 , version 1 (25-10-2007)
  • HAL Id : inria-00182433 , version 1
Wei Kang, Jean-Pierre Barbot. Discussions on observability and invertibility. NOLCOS, IFAC, Aug 2007, Pretoria, South Africa. ⟨inria-00182433⟩
240 Consultations
822 Téléchargements
