A phonetic concatenative approach of labial coarticulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Predicting the effects of labial coarticulation is an important aspect with a view to developing an artificial talking head. This paper describes a concatenation approach that uses sigmoids to represent the evolution of labial parameters. Labial parameters considered are lip aperture, protrusion, stretching and jaw aperture. A first formal algorithm determines the relevant transitions, i.e. those corresponding to phonemes imposing constraints on one of the labial parameters. Then relevant transitions are either retrieved or interpolated from a set of reference sigmoids which have been trained on a speaker specific corpus. This labial corpus is made up of isolated vowels, CV, VCV, VCCV and 100 sentences. A final stage consists in improving the overall syntagmatic consistency of the concatenation.
IS070531.pdf (305.17 Ko) Télécharger le fichier
inria-00184252 , version 1 (30-10-2007)
  • HAL Id : inria-00184252 , version 1
Vincent Robert, Yves Laprie, Anne Bonneau. A phonetic concatenative approach of labial coarticulation. INTERSPEECH 2007, ISCA, Aug 2007, Antwerp, Belgium. pp.1402-1405. ⟨inria-00184252⟩
208 Consultations
127 Téléchargements
