Qualitative stability patterns for Lotka-Volterra systems on rectangles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a qualitative analysis of the Lotka-Volterra differential equation within rectangles that are transverse with respect to the flow. In similar way to existing works on affine systems (and positively invariant rectangles), we consider here nonlinear Lotka-Volterra n-dimensional equation, in rectangles with any kind of tranverse patterns. We give necessary and sufficient conditions for the existence of symmetrically transverse rectangles (containing the positive equilibrium), giving notably the method to build such rectangles. We also analyse the stability of the equilibrium thanks to this transverse pattern. We finally propose an analysis of the dynamical behavior inside a rectangle containing the positive equilibrium, based on Lyapunov stability theory. More particularly, we make use of Lyapunov-like functions, built upon vector norms. This work is a first step towards a qualitative abstraction and simulation of Lotka-Volterra systems.
RR-6346.pdf (327.09 Ko) Télécharger le fichier
inria-00186247 , version 1 (08-11-2007)
inria-00186247 , version 2 (08-11-2007)
  • HAL Id : inria-00186247 , version 2
Laurent Tournier, Jean-Luc Gouzé. Qualitative stability patterns for Lotka-Volterra systems on rectangles. [Research Report] RR-6346, INRIA. 2007, pp.16. ⟨inria-00186247v2⟩
302 Consultations
340 Téléchargements
