A coupled system of PDEs and ODEs arising in electrocardiograms modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the well-posedness of a coupled system of PDEs and ODEs arising in the numerical simulation of electrocardiograms. It consists of a system of degenerate reaction-diffusion equations, the so-called bidomain equations, governing the electrical activity of the heart, and a diffusion equation governing the potential in the surrounding tissues. Global existence of weak solutions is proved for an abstract class of ionic models including Mitchell-Schaeffer, FitzHugh-Nagumo, Aliev-Panfilov and MacCulloch. Uniqueness is proved in the case of the FitzHugh-Nagumo ionic model. The proof is based on a regularisation argument with a Faedo-Galerkin/compactness procedure.
RR-6352.pdf (301.62 Ko) Télécharger le fichier
inria-00186852 , version 1 (12-11-2007)
inria-00186852 , version 2 (13-11-2007)
inria-00186852 , version 3 (13-11-2007)
  • HAL Id : inria-00186852 , version 3
Muriel Boulakia, Miguel Angel Fernández, Jean-Frédéric Gerbeau, Nejib Zemzemi. A coupled system of PDEs and ODEs arising in electrocardiograms modelling. [Research Report] RR-6352, INRIA. 2007, pp.24. ⟨inria-00186852v3⟩
322 Consultations
517 Téléchargements
