Volume-Surface Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2006
Many algorithms in computer graphics improve their efficiency by using Hierarchical Space Subdivision Schemes (HS^3), such as octrees, kD-trees or BSP trees. Such HS^3 usually provide an axis-aligned subdivision of the 3D space embedding a scene or an object. However, the purely volume-based behavior of these schemes often leads to strongly imbalanced clustering. In this article, we introduce the VS-Tree, an alternative HS^3 providing efficient and accurate surface-based hierarchical clustering via a combination of a global 3D decomposition at coarse subdivision levels, and a local 2D decomposition at fine levels near the surface. First, we show how to efficiently construct VS-Trees over meshes and point-based surfaces, and analyze the improvement it offers for cluster-based surface simplification methods. Then we propose a new surface reconstruction algorithm based on the volume-surface classification of the VS-Tree. This new algorithm is faster than state-of-the-art reconstruction methods and provides a final semi-regular mesh comparable to the output of remeshing algorithms.
VSTree.pdf (9.42 Mo) Télécharger le fichier
VS-Trees_-_Eurographics_2006.ppt (4.41 Mo) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00187194 , version 1 (13-11-2007)
Tamy Boubekeur, Wolfgang Heidrich, Xavier Granier, Christophe Schlick. Volume-Surface Trees. Computer Graphics Forum, 2006, Proceedings of EUROGRAPHICS 2006, 25 (3), pp.399-406. ⟨10.1111/j.1467-8659.2006.00959.x⟩. ⟨inria-00187194⟩
441 Consultations
641 Téléchargements
