s'authentifier
version française rss feed
inria-00187253, version 1
Between umbra and penumbra
Julien Demouth () 1, Olivier Devillers () a2, Hazel Everett () 1, Marc Glisse () 1, Sylvain Lazard 1, Raimund Seidel b3
23rd Annual Symposium on Computational Geometry - SOCG 2007 Session 8A (2007) 265-274
Résumé : Computing shadow boundaries is a difficult problem in the case of non-point light sources. A point is in the umbra if it does not see any part of any light source; it is in full light if it sees entirely all the light sources; otherwise, it is in the penumbra. While the common boundary of the penumbra and the full light is well understood, less is known about the boundary of the umbra. In this paper we prove various bounds on the complexity of the umbra and the penumbra cast by a segment or polygonal light source on a plane in the presence of polygon or polytope obstacles. In particular, we show that a single segment light source may cast on a plane, in the presence of two triangles, four connected components of umbra and that two fat convex obstacles of total complexity n can engender Omega(n) connected components of umbra. In a scene consisting of a segment light source and k disjoint polytopes of total complexity n, we prove an Omega(nk^2+k^4) lower bound on the maximum number of connected components of the umbra and a O(nk^3) upper bound on its complexity. We also prove that, in the presence of k disjoint polytopes of total complexity n, some of which being light sources, the umbra cast on a plane may have Omega(n^2k^3 + nk^5) connected components and has complexity O(n^3k^3). These are the first bounds on the size of the umbra in terms of both k and n. These results prove that the umbra, which is bounded by arcs of conics, is intrinsically much more intricate than the full light/penumbra boundary which is bounded by line segments and whose worst-case complexity is in Omega(n alpha(k) +km +k^2) and O(n alpha(k) +km alpha(k) +k^2), where m is the complexity of the polygonal light source.
  • Domaine : Informatique/Géométrie algorithmique
  • Mots-clés : complexity – discontinuity mesh – penumbra – shadows – umbra
  • inria-00187253, version 1
  • oai:hal.inria.fr:inria-00187253
  • Contributeur :
  • Soumis le : Mercredi 14 Novembre 2007, 09:51:06
  • Dernière modification le : Jeudi 22 Novembre 2007, 11:49:04
tous les articles de la base du CCSd...
