Estimation of Mars surface physical properties from hyperspectral images using Sliced Inverse Regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Visible and near infrared imaging spectroscopy is a key remote sensing technique to study and monitor planet Mars. Indeed it allows the detection, mapping and characterization of minerals as well as volatile species that often constitute the first step toward the resolution of key climatic and geological issues. These tasks are carried out by the spectral analysis of the solar light reflected in different directions by the materials forming the top few millimeters or centimeters of the ground. The chemical composition, granularity, texture, physical state, etc. of the materials determine the morphology of the hundred thousands spectra that typically constitute an image. Radiative transfer models simulating the propagation of solar light through the Martian atmosphere and surface and then to the sensor aim at evaluating numerically the direct and quantitative link between parameters and spectra. Then techniques must be applied in order to reverse the link and evaluate the properties of atmospheric and surface materials from the spectra. Processing all the pixels of an image finally provides physical and structural maps. We use a regularized version of SIR method (K.C. Li, Sliced Inverse Regression for dimension reduction, Journal of the American Statistical Association, 86:316-327, 1991) combined to a linear interpolation to reverse the previous numerical link. For that purpose we first generate numerous cor- responding pairs of parameters - synthetic spectra by direct radiative transfer modeling in order to constitute a learning database. The SIR step allows to reduce the dimension of the spectra (usually 184 wavelengths) in order to overcome the curse of dimensionality. Then, a linear interpolation is used to relate the reduced components of a spectrum to a given physical parameter value. Such inverted link is applied to a real dataset of hyperspectral images collected by the OMEGA instrument (Mars Express mission).
RR-6355.pdf (20.32 Mo) Télécharger le fichier
inria-00187444 , version 1 (14-11-2007)
inria-00187444 , version 2 (15-11-2007)
  • HAL Id : inria-00187444 , version 2
Caroline Bernard-Michel, Sylvain Douté, Laurent Gardes, Stéphane Girard. Estimation of Mars surface physical properties from hyperspectral images using Sliced Inverse Regression. [Research Report] RR-6355, INRIA. 2007, pp.91. ⟨inria-00187444v2⟩
453 Consultations
132 Téléchargements
