Intégration de la sémantique dans les Grammaires d'Interaction
This work is done in the context of the Masters in Computer Science, specialization in "Natural Language Processing (NLP)". It concerns the "Integration of semantics in Interaction Grammars (IG)" and studies how the syntax/semantics interface used for other formalisms can be adapted to IG. The solution proposed is implemented in a parser called LEOPAR.
Informatique et langage [cs.CL]
