Nesting ocean models
This note is focused on the problem of providing boundary conditions for regional ocean models. It is shown that usual methods generally do not address the correct problem, but more or less approaching ones. A tentative classification of these methods is proposed. Then their theoretical foundations are discussed, and recommendations are given.
