A subdivision arrangement algorithm for semi-algebraic curves: an overview - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Julien Wintz
  • Fonction : Auteur
  • PersonId : 844680
Bernard Mourrain
We overview a new method for computing the arrangement of semi-algebraic curves. A subdivision approach is used to compute the topology of the algebraic objects and to segment the boundary of regions defined by these objects. An efficient insertion technique is described, which detects regions in conflict and updates the underlying arrangement structure. We describe the general framework of this method, the main region insertion operation and the specializations of the key ingredients for the different types of objects: implicit, parametric or piecewise linear curves.
wintz-ArrangementSemiAlgebraicCurves.pdf (330.3 Ko) Télécharger le fichier
inria-00189560 , version 1 (21-11-2007)
Julien Wintz, Bernard Mourrain. A subdivision arrangement algorithm for semi-algebraic curves: an overview. 15th Pacific Conference on Computer Graphics and Applications, Ron Goldman, Oct 2007, Lahaina, Maui, Hawaii, United States. pp.449-452, ⟨10.1109/ISBN0-7695-3009-5⟩. ⟨inria-00189560⟩
196 Consultations
385 Téléchargements
