Probabilistic Estimation of Response Times Through Large Deviations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We apply large deviation theory to assess the probability that the average, or the sum, of the response times of a sequence of consecutive aperiodic jobs is below a given threshold. This coarse-grained performance metric is for instance adapted to evaluate the responsiveness of a soft-real system or the freshness of input data consumed by an algorithm. The technique proposed works with distribution of response times as input but does not require that the distribution obeys a closed-form equation. Indeed, it can accept empirical distributions given under the form of frequency histograms obtained, for instance, by monitoring the system. Future work should be devoted to further assess the applicability of the proposal and relax some technical assumptions.
wip_NNLCRS.pdf (92.84 Ko) Télécharger le fichier
inria-00191163 , version 1 (27-11-2007)
  • HAL Id : inria-00191163 , version 1
Nicolas Navet, Liliana Cucu, René Schott. Probabilistic Estimation of Response Times Through Large Deviations. Work-in Progress of the 28th IEEE Real-Time Systems Symposium (RTSS'2007 WiP), Dec 2007, Tucson, United States. ⟨inria-00191163⟩
159 Consultations
160 Téléchargements
