A Location-Unaware Distributed Clustering Algorithm for Mobile Wireless Networks Using Fuzzy Logic
This paper proposes a decentralized algorithm to organize an ad hoc sensor network into clusters by using Fuzzy Logic. Each sensor uses a Fuzzy decision making process to find the best Cluster Head. Simulation shows that this protocol is able to dynamically adapt to network mobility and also shows that with fuzzy logic we have stable clusters and so a cluster head have greater lifetime. Therefore respect to mobility, we have the minimum message exchange and so minimum energy consumption.
