An H∞ LPV Design for Sampling Varying Controllers : Experimentation with a T Inverted Pendulum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Sename
Daniel Simon
This report deals with the adaptation of a real-time controller's sampling period to account for the available computing resource variations. The design of such controllers requires a parameter-dependent discrete-time model of the plant, where the parameter is the sampling period. A polytopic approach for LPV (Linear Parameter Varying) systems is then developed to get an H∞ sampling period dependent controller. A reduction of the polytope size is here performed which drastically reduces the conservatism of the approach and makes easier the controller implementation. Some experimental results on a T inverted pendulum are provided to show the efficiency of the approach.
Automatique
RR-6380.pdf (935.76 Ko) Télécharger le fichier
inria-00193865 , version 1 (04-12-2007)
inria-00193865 , version 2 (05-12-2007)
inria-00193865 , version 3 (27-01-2009)
  • HAL Id : inria-00193865 , version 3
David Robert, Olivier Sename, Daniel Simon. An H∞ LPV Design for Sampling Varying Controllers : Experimentation with a T Inverted Pendulum. [Research Report] RR-6380, INRIA. 2007, pp.25. ⟨inria-00193865v3⟩
395 Consultations
297 Téléchargements
