A Feature Based Navigation System for an Autonomous Underwater Robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present a system for autonomous underwater navigation as implemented on a Nekton Ranger autonomous underwater vehicle, AUV. This is one of the first implementations of a practical application for simultaneous localization and mapping on an AUV. Besides being an application of real-time SLAM, the implemtation demonstrates a novel data fusion solution where data from 7 sources are fused at different time scales in 5 separate estimators. By modularizing the data fusion problem in this way each estimator can be tuned separately to provide output useful to the end goal of localizing the AUV, on an a priori map. The Ranger AUV is equipped with a BlueView blazed array sonar which is used to detect features in the underwater environment. Underwater testing results are presented. The features in these tests are deployed radar reflectors.
fsr_06.pdf (2.12 Mo) Télécharger le fichier
inria-00194676 , version 1 (07-12-2007)
  • HAL Id : inria-00194676 , version 1
John Folkesson, Jacques Leederkerken, Rob Williams, Andrew Patrikalakis, John J. Leonard. A Feature Based Navigation System for an Autonomous Underwater Robot. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00194676⟩
Collections
FSR2007
118 Consultations
386 Téléchargements
