Reactive Collision Avoidance for Unmanned Aerial Vehicles using Doppler Radar - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Research into reactive collision avoidance for unmanned aerial vehicles has been conducted on unmanned terrestrial and mini aerial vehicles utilising active Doppler radar obstacle detection sensors. Flight tests conducted by flying a mini UAV at an obstacle have confirmed that a simple reactive collision avoidance algorithm enables aerial vehicles to autonomously avoid obstacles. This builds upon simulation work and results obtained using a terrestrial vehicle that had already confirmed that active sensors and a reactive collision avoidance algorithm are able to successfully find a collision free path through an obstacle field.
fsr_53.pdf (225.86 Ko) Télécharger le fichier
inria-00195933 , version 1 (11-12-2007)
  • HAL Id : inria-00195933 , version 1
Andrew Viquerat, Lachlan Blackhall, Alistair Reid, Salah Sukkarieh, Graham Brooker. Reactive Collision Avoidance for Unmanned Aerial Vehicles using Doppler Radar. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00195933⟩
Collections
FSR2007
128 Consultations
1765 Téléchargements
