s'authentifier
version française rss feed
inria-00198595, version 1
Information Flow Testing
Gurvan Le Guernic () a1
Annual Asian Computing Science Conference 4846 (2007)
Résumé : Noninterference, which is an information flow property, is typically used as a baseline security policy to formalize confidentiality of secret information manipulated by a program. Noninterference verification mechanisms are usually based on static analyses and, to a lesser extent, on dynamic analyses. In contrast to those works, this paper proposes an information flow testing mechanism. This mechanism is sound from the point of view of noninterference. It is based on standard testing techniques and on a combination of dynamic and static analyses. Concretely, a semantics integrating a dynamic information flow analysis is proposed. This analysis makes use of static analyses results. This special semantics is built such that, once a path coverage property has been achieved on a program, a sound conclusion regarding the noninterfering behavior of the program can be established.
  • a –  Kansas State University
  • 1 :  LANDE (INRIA - IRISA)
  • CNRS : UMR6074 – INRIA – Institut National des Sciences Appliquées (INSA) - Rennes – Université de Rennes 1
  • Domaine : Informatique/Langage de programmation
    Informatique/Cryptographie et sécurité
  • Mots-clés : Noninterference – Testing – Confidentiality – Information Flow
  • inria-00198595, version 1
  • oai:hal.inria.fr:inria-00198595
  • Contributeur :
  • Soumis le : Lundi 17 Décembre 2007, 15:56:33
  • Dernière modification le : Lundi 17 Décembre 2007, 16:07:43
tous les articles de la base du CCSd...
