s'authentifier
version française rss feed
inria-00202674, version 2
Reachability in linear dynamical systems
Emmanuel Hainry () a1
Computability in Europe 5028 (2008) 241-250
Résumé : Dynamical systems allow to modelize various phenomena or processes by only describing their local behaviour. It is however useful to understand the behaviour in a more global way. Checking the reachability of a point for example is a fundamental problem. In this document we will show that this problem that is undecidable in the general case is in fact decidable for a natural class of continuous-time dynamical systems: linear systems. For this, we will use results from the algebraic numbers theory such as Gelfond-Schneider's theorem.
  • a –  Université Henri Poincaré - Nancy I
  • 1 :  CARTE (INRIA Lorraine - LORIA)
  • CNRS : UMR7503 – INRIA – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
  • Domaine : Informatique/Autre
  • Mots-clés : Dynamical Systems – Reachability – Skolem-Pisot problem – Gelfond-Schneider Theorem
  • Versions disponibles :  v1 (07-01-2008) v2 (16-04-2008)
  • inria-00202674, version 2
  • oai:hal.inria.fr:inria-00202674
  • Contributeur :
  • Soumis le : Mercredi 16 Avril 2008, 15:53:48
  • Dernière modification le : Mercredi 8 Octobre 2008, 15:10:37
tous les articles de la base du CCSd...
