Estimating Vehicle Position Using Few Range Measurements to a Known Curved Surface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Michael Kokko
  • Fonction : Auteur
  • PersonId : 845881
Franz Hover
  • Fonction : Auteur
  • PersonId : 845882
This paper presents a method by which data from two or more rangefinders can be combined to estimate vehicle position when operating in proximity to a surface of known curvature. Estimates are combined in an Extended Kalman Filter which accounts for the expected transformation of sensor noise. Although developed for use with Autonomous Underwater Vehicles, this curvature-based localization technique can be applied to any mobile agent capable of measuring its range to a previously-mapped surface.
fsr_81.pdf (1.45 Mo) Télécharger le fichier
inria-00202693 , version 1 (07-01-2008)
  • HAL Id : inria-00202693 , version 1
Michael Kokko, Franz Hover. Estimating Vehicle Position Using Few Range Measurements to a Known Curved Surface. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00202693⟩
Collections
FSR2007
35 Consultations
176 Téléchargements
