Fitted Q-iteration in continuous action-space MDPs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We consider continuous state, continuous action batch reinforcement learning where the goal is to learn a good policy from a sufficiently rich trajectory generated by some policy. We study a variant of fitted Q-iteration, where the greedy action selection is replaced by searching for a policy in a restricted set of candidate policies by maximizing the average action values. We provide a rigorous analysis of this algorithm, proving what we believe is the first finite-time bound for value-function based algorithms for continuous state and action problems.
rlca.pdf (129.85 Ko) Télécharger le fichier
inria-00203359 , version 1 (09-01-2008)
  • HAL Id : inria-00203359 , version 1
Andras Antos, Rémi Munos, Csaba Szepesvari. Fitted Q-iteration in continuous action-space MDPs. Neural Information Processing Systems, 2007, Vancouver, Canada. ⟨inria-00203359⟩
231 Consultations
257 Téléchargements
