A First Experimentation on High-Level Tooling Support upon Fractal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this abstract, we present a first experimentation on tooling support based on Fractal component model. The motivations which encouraged us were to provide an homogeneous design environment for the user to specify Fractal applications.
workshop_Fract.pdf (94.16 Ko) Télécharger le fichier
inria-00204114 , version 1 (12-01-2008)
  • HAL Id : inria-00204114 , version 1
Frédéric Loiret, David Servat, Lionel Seinturier. A First Experimentation on High-Level Tooling Support upon Fractal. ECOOP 2006 - Workshop Fractal, Jul 2006, Nantes, France. ⟨inria-00204114⟩
83 Consultations
38 Téléchargements
